Oil Change Questions
Old 07-24-2008 | 02:31 AM
warsanrotts's Avatar
Default Oil Change Questions
I have 1500 miles on my 08 ZZR600 and getting ready for another oil change. I was considering going with Amsoil synthetic. Is it too soon to start using synthetic? I have heard that you should wait a while but can't remember how long. Also, looking for recomendations on oil filter brand?
Thanks,
Old 07-25-2008 | 02:48 AM
jay_sco's Avatar
I used Castrol semi-synthetic at 2000 miles and it seems to be doing just fine 700 miles later, for the filter I got a Kawasaki. I don't see why you would have to wait to use synthetic.
Old 07-25-2008 | 10:34 AM
AHUFFY's Avatar
You should be good to change to full/semi-synthetic. And I'm probibly wrong but I'm fairly certain that in order to get your cylinders/gaskets, etc. to seal up tight and "run" more smoothly. And as for the oil filter I haven't heard anyone get too excited about it. I think if you go KAWI you'll be alright.
Old 07-27-2008 | 05:27 AM
kx slaughter king's Avatar
after 1500 miles you can use synthetic if you want, dosent make much of a diff after 15hun
Old 07-28-2008 | 03:45 AM
zzrick's Avatar
I used amsoil this time because my local castrol supplier moved...it seems okay but I liked the castrol R4 better.
Old 07-28-2008 | 08:44 AM
Bluebeast's Avatar
you'll be ok if you use synthic i have been using it since my first oil change i noticed a little difference when i use sythinc the first time.
Old 08-02-2008 | 12:17 AM
What have you found to be the best oil filter wrench for getting in from the front? Channel locks worked but I want to pick up a filter wrench.
Old 08-02-2008 | 02:01 AM
N3WWL's Avatar
I bought the OEM filter wrench cup from Kawi, although a bit pricey.
Old 08-03-2008 | 04:08 AM
zzrick's Avatar
I use K&N filters usually, and they have the nut on the end.
Old 08-03-2008 | 10:54 AM
Nice idea with the nut! K&N is what I'm going with next time. And only a buck more than the Kawi.
Quick Reply: Oil Change Questions
