bike wont start.
Old 02-02-2010 | 12:54 AM
unko_636's Avatar
what kind of numbers do yall need from whare and what? I just check the timing once more and its dead on. I recheck the vavle gaps there with in tolerance.
Ok so i dumped some gass in to the carbs and held it wide open then tryed to start it. it fired up for a second then died but then it didn't want to fire up again? now i think its a fuel issue so i took the carbs apart and cleaned it out. checked to fuel flow, that seems to be fine. I dont have a pressure gauge for the fuel or comprsion so i cant get numbers for these two.
oh i hate carbs im not very good with them (I like fuel injection less bull **** to me) so I dont really now if i check and clean everything that I should have. All i knew was not to seperate the carbs from each other so i dont have to sync them again.
Old 02-02-2010 | 01:13 AM
motomike's Avatar
it sounds like fuel but it's weird it happened when you did valves.have you disconnected the fuel line to make sure your fuel pump is putt'n out ?
Old 02-02-2010 | 01:22 AM
unko_636's Avatar
yes I just did that its getting fuel. lots of it.
Old 02-02-2010 | 06:27 AM
I still place my gauges on to double check the synch. Just a piece of mind and is cheaper then crashing.
Old 02-27-2010 | 06:52 AM
unko_636's Avatar
Ok First. sorry this is taking so long to update but im really broke so things take longer to get.
ok so i had the carbs rebuild and added a stage 1 jet kit. I re did the timming again and rechecked the shims there all good. what type of numbers do you need?
IQOUTLAW
03-23-2010 03:33 PM
pfft84
Ninja 250R
03-22-2007 10:22 AM
05ninjazx6r
03-30-2006 12:47 AM
DJNYC
09-21-2005 05:00 AM
