DynoJet Quickshifter Group Buy
The DynoJet Quick Shifter Retails for $284.95
This group buy is a steel!!
I only need 5 people to make this group buy happen but the more the better.
After this group buy my regular price will go up to $244.95 so don’t miss out.
The Dynojet Quick Shifter (DQS) kit allows you to make full throttle, clutchless up shifts. Once installed, the rider can shift up simply by pressing or lifting (depending on the bike) the gear shift lever. The amount of “kill time” is adjustable by the user via the provided software. The user can also set a minimum rpm for the system to function. This keeps the system from activating at too low of an rpm, such as low speed road riding.
The DQS is compatible with all PCIIIusb's which you can buy from cyclemart USA for $254.96 and plugs directly into the expansion port. No cutting or splicing of the bike's wiring is required.
Note: PCII, PCIII, and PCIIIr model Power
Commanders cannot use this kit
Have questions? Please ask. If you are local to Fort Worth we can install it for you too.
Mindy at customer service will not be able to answer your Technical questions but you can leave a message and I will call you back or just post up here.
To enter the group buy call Mindy and place a quick shifter on order. Make sure to mention Kawasaki Forums. We will not charge any cards until all 5 are sold Then we will ship out the 5 or more quick shifters. Please post up your intent to order so others know how many are already sold.
I will sell up to 10 at this price. The group buy will end on July 23rd or when 10 quickshifters are sold.
Terry
www.cyclemartusa.com
1-866-204-0942
Group Buy Price = $213.77
The lowest I found on the net was $248.95. This group buy is a steel!!
About Quick Shifters
Normally during up shifting you must roll off of the throttle and pull in the clutch in order to engage the next higher gear. In racing (both drag and road race) split seconds count. Rolling off the throttle, even slightly, slows your times and can be the difference between winning and losing.The Dynojet Quick Shifter (DQS) kit allows you to make full throttle, clutchless up shifts. Once installed, the rider can shift up simply by pressing or lifting (depending on the bike) the gear shift lever. The amount of “kill time” is adjustable by the user via the provided software. The user can also set a minimum rpm for the system to function. This keeps the system from activating at too low of an rpm, such as low speed road riding.
Terry
1-866-204-0942
RE: DynoJet Quickshifter Group Buy
No you would have to have the PCIII USB.
It does not works with the PCII or PCIIIr either.
I sell the PCIII usb for 254.96 on my site.
http://www.cyclemartusa.com/productd...ductId=2482225
The ignition module is a seperate add-on but you don't need it to make the quickshifter work. However the ignition module will give you better bottom end & midrange power plus more topend speed/ HP!
