oops
RE: oops
ORIGINAL: evil636
sand, and if you sand to mch, reapply the bondo and try again. [:'(] it gets dusty quick so be carefull. wear a dust mask.
RE: oops
now should i camo the bike if i get go full fairings. The problem with the sanding is i kept going deeper I think my biggest problem I had was I was applying bondo using a rubber speader, and I would try to put as little of bondo as possible to minimize sanding(i found out the hard way the first time) and when I applied the bondo I wend the wrong direction with the scrapper, and probably the sanding as well. Has anyone ever got a good paint job from a rattle can. I've seen at walmart they have a metalic blue rattle can for 10 bucks, I'm temped to try it and see. I was temped to get factory rattle can paint, but at 32 bucks a can for primor and paint, its almost not worth it even tring.
RE: oops
im painting my race truck with rattle cans and ill try to get some pics of the paint job i did on my buddys truck with krylon. straight 4 dollar can of paint and some 3 dollar clear and it looks better then the 600 bucks another buddy put into his truck. even the graphics came out sweet on his truck.
