do all zx6r shoot flames?
RE: do all zx6r shoot flames?
you can do that with any carbed bike if you whack the throttle close too fast from high rpm. Another think you can do is to leave it in gear, clutch out, turn the key off - flood the throttle for 2 or 3 secs, close the throttle then turn the key back to run... you will probably set of area car alarms with the report you generate. Note - repeated execution (ie - 50x+) of this WILL harm your valves and cylinder heads.
topic7
04-19-2008 09:21 PM
adam1
11-21-2007 06:24 PM
