1996 zx7
RE: 1996 zx7
here is a list of mods
1996 zx7 polished frame and swing arm,p.m wheels,blue anodized zx12 rotors,racetech gold springs,fox shock and spring,carbon fiber ram air tubes,blue led neon light kit,full muzzy exhaust with carbon fiber high mount can,full race replica decals,solo race shark skinz tail section,blue rk chain,2mm shaved head with 3 angle valve job,95 zx7rr crank,micro polished with counterbalances removed,Manley long rods ,Muzzy forged aluminum pistons,stock bore,cylinder walls deglazed,Muzzy adj,cam sprockets set at 105in,105ex, Muzzy adj ignition advancer set at 4 degrees,Muzzy reed block off plates(emisions removed)Muzzy 6 blade fan,qb carbon air box with kn,Vortex heat treated fron sprocket,sprocket specialist polished rear,performance machine custom wheels,Michelin soft tires,white face illumiglo gauges.
Ducativ2
10-26-2006 02:02 AM
