Rear blinkers
Rear blinkers
Due to the rear blinkers breaking when I drop the bike I would like to replace them with some flush mounted ones. I really like the looks of the below setup, but all the links are broken. Any idea which blinkers and taillights these are? I own an '06 BTW
Here are a couple of pics and links. You can also see the Tail light that we used to get rid of all the junk hanging down past the fender. Good luck.
Attachment 31252
Attachment 31253
Attachment 31254
Here are some links.
http://www.motorcycle-superstore.com/item.aspx?style=10822&department=661&Divis ion=6
http://www.motorcycle-superstore.com/item.aspx?style=14600&department=661&divis ion=6
http://www.acerbis.com/p106_handguard/1326.html
http://www.cyclepages.com/ProductGroupDisp.aspx?ProductGroupID=4002724
Well there you go, it took me a while to find all the places and pics, I hope this helps. Later man.
Attachment 31252
Attachment 31253
Attachment 31254
These are the ones I replaced mine with.
https://www.cyclegear.com/parts/spee...d-turn-signals
They're $20 at Cycle Gear and don't stick out as much. I bought them because my exhaust was melting the stock ones, a common problem with these bikes.
I used a set of Bikemaster generic amber marker lamps-work very well for the past 5 years. https://bikemaster.com/motorcycle-re...lear-bulb.html
One rider here did some press in semi-trailer clearance lights, but I cannot find the post. They were like $5 each, I bought four and will eventually install them. They were LED. Drill a hole, put in grommet, press in the LED/lense and done, wire it up. Not the most handsome set up, but I planned to do them either behind the side number plates or on the license plate set up for the rear.
I know the post is here and/or at ADVrider in the Long Term KLX250 thread.
I found RockabillSlapatt's LED signal set up. Low buck easy to do and virtually impervious to damage.
uneducatedstudent
09-09-2006 06:20 PM
