2011 kx250f idle problem
i have just bought a 2011 kx250f and it seems to have a problem with idling. after warning it up, it idles for 1 min and then seems to kill itself. i,ve tryed adjusting the idle screw (also the choke) but this does nothing for the problem only makes the bike run too high when riding.
any suggestions welcome.
today was first day taking the bike out for a spin.
Well there are many things effect to this problem. Like the bad spark or spark plug. or may be there is some problem in fuel circulation or air filter.
Thank You for your help and suggestions so far. We tried alot. Actually brought in another bike and switched over tanks, Injectiors, TPS and ECU and none of it changed the bike. I have a feeling it is with the hot cams, valves or the head. Does anyone know if the stage 2 hot cams need a different timing setting, a little more advance or retard on the intakes or exhaust?
solved my problem eventually. sorry for not posting earlier
there was a small part of the right exhaust valve spring broken and therefore not closing fully.. new valves and springs fitted now and my bike runs like a mouses' heart.
Thanks for letting us know.
i was checking valve clearance and whatever i did i could not get the clearance right. i decided it was time for new valves and reseating. when i had the head removed, i turned it over to inspect the valve heads and seats and low and behold i heard something move. i flipped over again and spotted a piece of the valve spring beside the top of the valve. removed it with a magnet and sent the head to my dealer to have valves and springs replaced under shop warranty.
09, 2011, 2011kx250f, 2012, 250f, adjust, adjustment, afjustment, forum, idle, kawasaki, kx, kx250f, problem, problems
