Off Road Taken your quad or bike off roading lately? Talk about it here.
1995 Kx250 will not start
Old 03-23-2013 | 06:48 PM
srw101's Avatar
Exclamation 1995 Kx250 will not start
I have a 1995 kx250 that refuses to kick start without priming spark plug hole or bump starting. Here's where I am:
Brand new cdi and ignition coil (verified good spark with inline tester)
Cleaned carb can see daylight through every orifice.
Stock pilot @ 45 not sure about needle
Air screw 2 turns out per manual
Compression test yielded 150 (low maybe)
Runs like a scalded dog after started revs beautifully
Floats I think are set right always gas in bowl
Never over flows
New plug always wet when checked
Help!
Old 03-23-2013 | 08:16 PM
Never over flows
I would just rebuild the carb. Seats/ needle and test the float.
I know on my CR480, I have to flood the carb for startup as well (big bore startup). Once started (literally one kick), I am stylin'
Old 03-23-2013 | 08:51 PM
srw101's Avatar
Sounds like a plan but I can't find a complete carb rebuild kit for a 95 kx250
Can only get bits and pieces.
Old 03-23-2013 | 09:06 PM
reference material: Kawasaki Motorcycle Parts 1995 KX250-K2 KX250 CARBURETOR Diagram
Old 03-24-2013 | 01:23 PM
srw101's Avatar
I do appreciate it but I was kinda hoping for an all in one carb rebuild kit that didn't cost me an arm and a leg. I'll probably have to break down and buy it piece by piece. Thank you though
Old 03-24-2013 | 03:25 PM
The float valve is kinda spendy. But that is what I was referring to as a part in your carb rebuild. I also like to float test the float or see if it is getting fuel logged. Then do a complete carb cleaning/soaking. Reassemble, set the float height, etc. Do a shake down cruise and adjust as necessary.
srw101
KX250 & KX250F
10-09-2012 05:05 AM
jontymiller
03-24-2012 09:11 PM
ajfelt
01-20-2009 03:53 AM
George SA
KX250 & KX250F
08-26-2007 07:34 PM
