horrible throttle
Old 03-18-2009 | 01:21 AM
wheel408's Avatar
Default horrible throttle
hey Everbody i got a 98 zx9 with a throttle with no return snap i tried a new cable no luck with that i was reading i can install a ignition advancer and it would solve the problem i need some suggestion before i go on and purchase anything else
thanks
Old 03-18-2009 | 04:36 AM
thanks
No throttle return snap as in that the throttle does not return properly? New grips rubbing can be an issue or the spring and cable hook up may not be correct.
Old 03-18-2009 | 04:47 PM
jeffzx9's Avatar
make sure your cables are lubed and properly routed. If the throttle is tight on the "open" twist, it may be binding on the "close" twist. Ignition advancer won't do much. Cams in Kaws are typically spec'd a bit hotter than (say) Suzuki. (THAT oughtta get some upset posters....but it's true.)
deej
03-18-2012 10:54 PM
Russian Rocket
11-02-2007 06:01 AM
iroc
Ninja 500R
15
10-26-2007 03:22 AM
ninja16
11-13-2006 07:10 AM
jayden
02-23-2006 09:25 PM
Quick Reply: horrible throttle
