swaped tanks, now gas pours out Carbs
Old 04-09-2008 | 01:46 PM
jaymade's Avatar
Default swaped tanks, now gas pours out Carbs
When I got the bike, the gas tank was beat up. Looks like a handle bar dent on left side. I found another tank, repainted and put back on. I didn't mess with anything else except tank & fairing. When I took it for a test ride it did great for about 2 miles then started running rough. I smelled like rich exhaust. Upon inspection, I noticed fuels pouring out carbs on the filter side. The bike runs great with out the tank on... but I can’t go too far that way.
Any ideas?
Old 04-09-2008 | 01:51 PM
Kohburn's Avatar
Default RE: swaped tanks, now gas pours out Carbs
sounds like your carb floats aren't working, it could be that there was some contamination (rust) that got into the carbs bowls and is keeping the needle valve of one or more carbs from closing.
Old 04-09-2008 | 02:23 PM
jaymade's Avatar
I noticed there isn't a petcock. just a diaphram with a pushbutton. so the floats should cut fuel off when bowls fill.allright... Fun Fun, sounds like i will be breaking it down. Can't have the garage smelling like a refinery.
Thanks
Old 04-09-2008 | 02:59 PM
Kohburn's Avatar
not familiar with your bike specificly so i can't say what he diaphram you are talking about is for. if you don't have a petcock you may want to look into adding one from a later bike like the late 90's zx6's
Old 04-09-2008 | 03:04 PM
Kohburn's Avatar
just looking at the partlist for your bike... does your bike have a fuel gauge?
Old 04-09-2008 | 03:06 PM
Kohburn's Avatar
the inside of your carburators
http://webservices.motorsportdealers...1378/E1612.Gif
if that link doesn't work then go to
http://www.cheapcycleparts.com/pages.../Kawasaki.aspx
and select ZX750-F4 Ninja 750R (1990) (that is your bike right?)
then select the part system you want.
Old 04-09-2008 | 03:15 PM
jaymade's Avatar
It does have a fuel gauge
Old 04-09-2008 | 03:18 PM
jaymade's Avatar
cool , now i got something to go by,
Thanks
J
leftlane
02-17-2011 12:21 AM
mattyw
09-20-2009 04:33 AM
LordVngr
01-22-2009 04:47 AM
2006636r
12-20-2007 04:53 AM
devestator_x
08-08-2005 12:09 AM
