OIL LEAKAGE
OIL LEAKAGE
I'M STARTING UP MY 93 ZX7R LAST WEEK FOR THE FIRST TIME SINCE OCTOBER OF LAST YEAR AND I GOT SMOKE COMMING OUT OF MY EXHAUST, SO I TOOK MY FAIRINGS OFF TO GIVE IT A LOOK AND I SEEN OIL LEAKING FROM THE BOTTOM OF MY EXHUAST..I FOLLOWED THE OIL FROM MY EXHUST UP TO THE MANIFOLD...THE OIL IS GOING IN THE SECOND MANIFOLD PIPE EVERY TIME I START MY BIKE AND I DON'T HAVE A CLUE WHY..CAN SOMEONE HELP ME? THANX
RE: OIL LEAKAGE
I BELIEVE SO..IT'S ONLY LEAKING FROM THE SECOND PIPE(FROM LEFT TO RIGHT) WHEN I START MY BIKE UP AND DON'T KNOW WHY..IT'S WASN'T LEAKING BEFORE I GARAGED IT LAST YEAR.
RE: OIL LEAKAGE
You will have two lines on cylinders #2 and #3 on the head. Standard banjo bolts with crush washers. Try snugging the seeping one down to torque and try that. Otherwise just get another crush washer. That is if the line itself is ok.
RE: OIL LEAKAGE
ORIGINAL: Bluebeast
that's posible. look to see if it's leaking from the top of the motor if it is then it's the valve cover gasket.
Jutboy
04-21-2006 06:05 PM
