buy used or rebuild-alternator?
90 H2 with 21000 mi.and my alternator belt snapped and killed my batt. Now the after installation there is no key off draw but the batt won't keep a charge. So the bike shop says the alternator is drawing 6v. So it's either a 200$ used alt. or try a rebuild... Any suggestions?? thanks, e
RE: buy used or rebuild-alternator?
hmm, a bad bearing on the alternator cause the belt to snap? They go bad by themselves (the belt). Your ground is good and you are confident with your new battery?
The belt was old and fraying before it snapped and I think the belt dressing gave her the edge to snap LOL. I took the alternator to the shop and the guy said it looked good and I explained whats going on and he mentioned that it sounds like a regulator. I pulled up a micro-fische and I see that my bike has a rectifier outside of the alternator too. I'm going to look into it today. The ground should be good I'll check it too, as for the batt. it's brand new from the bike shop.
sambeaux
06-11-2009 04:30 AM
