94 Zx7 - Rough Idle after oil change and plugs
Can't figure it out. I changed the oil, changed the plugs and put it all together. Bike starts great but after a few minutes it starts to run rough and dies. Will restart with a bit of throttle but dies. Also, the bike is hard to shift into gear from neutral.
Tried running down all the vacuum lines, inspected the fuel filter, all seems good. Any ideas?
RE: 94 Zx7 - Rough Idle after oil change and plugs
most likely its the plugs - what kind did you get and did you check the gap to make sure it was correct before installing them?
when a problem starts its usually because of the last thing you did.
even the ones that claim to be pregapped tend to be off from bouncing around inside the boxes during shipping. pick up a haynes manual (usually 11-13$) it should have the gap info along with other useful maintanance stuff
seizetheday4eva
08-14-2012 04:25 AM
Popsmear
08-15-2007 02:12 AM
