1992 K model starter clutch
Old 10-29-2009 | 05:04 PM
jzanutto's Avatar
Default 1992 K model starter clutch
anyone changed a starter clutch on an early 90s ZX7?
on my sons 92 K model its starting to make this "clunk" sound from the starter area when it starts up. The bike starts and runs fine, no continuous clunking when running and you can even push start the bike.
So I'm thinking either starter or clutch. (would be nice if its JUST the starter, but how often does that happen?)
Old 10-29-2009 | 05:51 PM
95451's Avatar
I Wish I could Help.
I Havnt Had That Happen Yet.
Sure Someone Will Be Able To Tell You Something
Old 10-29-2009 | 06:07 PM
jzanutto's Avatar
you have a K model too?
Old 10-29-2009 | 09:59 PM
95451's Avatar
Originally Posted by jzanutto
you have a k model too?
:d:d
Old 10-30-2009 | 03:56 AM
You could pull the starter and inspect the drive gear as you mentioned already and that would help tell you depending on the wear and the oil change contaminants.
Old 10-30-2009 | 05:05 PM
jzanutto's Avatar
looked at it yesterday. No indications that its coming from the starter drivetrain at all.
Probably going to look at the alternator drive chain assembly
Old 11-01-2009 | 05:07 AM
belt driven
Old 11-04-2009 | 04:37 PM
jzanutto's Avatar
Finally my son was able to get into the right side and have a look. The starter/alternator/oilpump drive chain was excessively loose. Looks like the starter would engage and bunch up the chain, making the pop or clunk sound. Then when the bike started the primary would take the slack out of the chain. Good thing that was found now before the chain or teeth got damaged.
there is a chain adjuster, and chain tensioner over there behind the clutch basket, so he followed the adjustment and tensioner re-set procedure. Its all nice and tight now.
Old 11-04-2009 | 07:06 PM
95451's Avatar
Congrats On The Fix
Old 11-05-2009 | 03:14 AM
congrats on the fix.
lee1980
07-16-2010 12:24 PM
pastaman
03-01-2008 01:29 PM
clb3carl
Classic Sportbikes
10-22-2007 04:34 AM
dman3290
05-22-2007 01:12 AM
