01' zx7r NO POWER
RE: 01' zx7r NO POWER
LOL ez.. calm down my man..
ok. the easiest way to hot wire these things is to jump the white and brown wires together.
BUT
you hafta supply 6 volts to the gray wire. this isthe logic voltage supply to the ECU. if it sees less than 5V or way more than 6 V (like 12) it will not work.
the red and blue wires are just for show.. lol.. nah. those go to lighting.
i wanna say a 100 ohm resistor will do the trick. theres a resistor in the ignition switch, as i've said elsewhere in writups and all, but i really don't know the value of it. i just metered the harness and got 104. xx ohms on the white abnd gray.. could be a backfed value tho, so dont quote me on 100 ohms just to release liability..lol
you're lucky i have my bike all ripped apart!!!! haha..
oh, and the ecu is on the throttle side on the sub frame, almost directly under the rear seat.
disclaimer. if i ever hear of anyone, anywhere using this info for the theft of a bike, i will personally travel to where you(thief) live, and after your court date, see to it that you're raped by a bitter and senile geriatric.
BUT
ORIGINAL: whitehendrix
thanks alot!
EDIT: HOW PRIMITIVE!! stupid commies
