Will the cheap oem way of clutch repair work?
I was looking at the clutch skimatics on an OEM diagram and it looks like the stock friction plates and parts range from about 9 to 14 bucks.. I'm out of work right now and can't afford 150 or what ever to buy a kevlar clutch kit.. I'm not a stunter or crazy rider yet.. I bought the bike used with 9400 miles on it.. Only putting about 300 miles on it and the clutch went today.. Right about the time I switched my clutch and brake levers to carbon fiber.. Made one ride with them realizing the handles weren't adjusted right and then I found my clutch went same time..
it really slips when I open it up.. When I hit like 9 it'll jump to 12 or 13..
As you can see by the list and photo. I think most of the parts I need are really cheap.. I'm just not sure exactly which ones I need.!
13087: HUB-CLUTCH 545426-001 $89.18
13088: PLATE-FRICTION 545481-001 $14.00
13089: PLATE CLUTCH STEEL
USE WITH 13087-02 1489-001 $9.98
13089A: PLATE-CLUTCH 545523-001 $9.98
13089B: PLATE-CLUTCH,T=1.4 545547-001 $8.96
13091: HOLDER,CLUTCH,SPRING 545587-001 $6.86
13095: HOUSING-COMP-CLUTCH 546180-001 $299.15
13102: RELEASE-COMP-CLUTCH 546725-001 $33.40
13187: PLATE-CLUTCH OPERATIN 549799-001 $44.76
46102: ROD 598227-001 $17.52
92015: NUT,20MM
USE FOR 92026 1065 622294-001 $7.30
92022: WASHER 623202-001 $5.80
92026: WASHER TH 25.5X47X2.5
624074-001 $6.04
92026A: SPACER 624282-001 $7.06
92028: BUSHING 625524-001 $21.86
92045: BEARING-BALL
KZ1000-P1/P2/P3 1499-001 $8.54
92046: BEARING-NEEDLE 627405-001 $14.98
92144: SPRING,FRICTION PLATE 634558-001 $5.44
92144A: SPRING,CLUTCH OPERATI
(OPTION) 634569-001 $6.04
92145: SPRING,ROD 634715-001 $1.48
92145A: SPRING 634774-001 $2.53
92150: BOLT,CLUTCH OPERATING 635235-001 $2.90
92200: WASHER,FRICTION PLATE 638175-001 $6.29
92200A: WASHER,11.2X18X0.5 638240-001 $1.48
92200B: WASHER,12X18.5X0.5 638259-001 $1.53
92015: NUT,20MM
624074-001 $6.04
92045: BEARING-BALL
RE: Will the cheap oem way of clutch repair work?
Of course to do it right, you should buy the entire kit!!.. but cheaply, should only need 13088, 89, a+b.. If I'm wrong Somebody will correct me..
You should be able to get a Barnett kit for about the same price as stock. Remember that the stock plate prices are $14 each and you will need 7 I think. The 13088's Friction Plates are what you really need.
CousinLarry
07-03-2012 02:30 AM
woodrow
08-22-2009 09:27 PM
