wheel interchange ???
Looking for 100% percentconfirmation if a 2002 ZX6 front wheel will interchance with 2004 ZX6RR or not. Having one heck of a time finding a front wheel for my 04. my rotors are fine and tire is new I just need a front rim.
Josh
Josh
RE: wheel interchange ???
NOTa100%surethe 02wheelwill fit 03-04. The rotors are larger and you can use spacers and longer bolts to make those work also. Let me know, I have some.
CORRECTION: Made a mistake reading the above. Thought it said 05 instead of 02. Looks like the same wheel on the 02 & 04 however. I am having someone check to make sure.
speed hit me up with some price info. The only thing (other than weather) keeping my 04 off the track is a front rim and a fender. I've taken it around the block a few times but the wobble at the bars isn't good for my confidence level . I've had the ten out a few times already and rode my (gasp) CBR once.
Josh
ps still trying to find time to get pics up.
Josh
OOps, I just re-read your post. I first thought you said 2005 wheel on your 2004. I will find out about the 02 wheel and get back to you. From the looks of it, it looks the same. You will most likely have to use your stock rotors.
2002, atv, atvs, front, interchange, interchangeability, interchanging, kawasaki, ninjas, rim, tire, wheel, wheels, zx6e
