Transmission Problelms
RE: Transmission Problelms
read skg's problem, that will start to happen to you next
https://www.kawasakiforums.com/m_156399/tm.htm
ORIGINAL: Baby Ninja
Well, at first it was doing it mostly when I'm leaned to the left and accelerating hard. Lately though, it has been doing it on both sides and sometimes even when upright. Around town it has been okay. It's just when I start to head to the twisties and local backroads and riding hard. Could it also be that my 2nd and 3rd gear are going out. I have not yet encounter doing it on the 4th or higher gears?
from what i've read about kawasaki's it can be caused by the shift forks and shift drum wear down and not fully engaging the gear dogs. but once its gone on long enough to progress to the point you describe the gear dogs would at the very least need to machined flat again if not replacing the whole gear.
i just picked up a replacement set of shift forks and shift drum on ebay. i'm going to work on cryo treating the shift drum and add a thin layer of material to the wear surface of the shift forks with a much higher hardness than stock (along the lines of tungsten carbide). that way if I ever have to swap the parts in i'll have a superior set that won't wear out for a long long time.
