tranns question
Old 06-25-2008 | 02:09 AM
l780064's Avatar
Default tranns question
i have a 2004 zx6r and very rarely but it still happens and i would like to know if it is rider error or i need to get it checked out i will go to shift and either it doesnt go the shifter moves up but it doesnt shift or i will click up and it will be like it is in neutral but i am not i am in between lets say 3 and 4 gear. the bike has 4000 miles dont know if that makes a difference
Old 06-26-2008 | 01:12 AM
speedracer138's Avatar
Default RE: tranns question
First adjust & lube your chain. These bikes seem to be finicky when shifting if the chain is loose. Second; try adjusting the shift lever down a little so when you shift up, it puts more pressure and egages in the next gear fully.
Old 06-29-2008 | 08:03 PM
Crasher986's Avatar
Factory Pro Shift Star kit should help out if you do have a minor problem, even if it is poor technique. If your trans is in good shape, it will help keep it that way.
1stCruiser
04-23-2011 03:27 AM
fastex500
03-28-2008 01:41 AM
BlueDream
11-21-2007 05:35 PM
Quick Reply: tranns question
