torque specs for clutch springs for the 03-04 zx6r's
Old 11-02-2007 | 07:16 PM
768 Ryda's Avatar
Default torque specs for clutch springs for the 03-04 zx6r's
hey guy's do anybody no the torque specs for the clutch springs for the 03-04 zx6r's, i was going to change my clutches out and i don't have a manual
Old 11-02-2007 | 11:57 PM
05ZX6R's Avatar
Default RE: torque specs for clutch springs for the 03-04 zx6r's
The following is for a 2005 ZX-6R, there may be a difference since the 2005's have a slipper type clutch but it should be close.
Torque - Clutch Spring Bolts: 8.8 N·m (0.90 kgf·m, 78 in·lb)
Old 11-03-2007 | 12:10 AM
768 Ryda's Avatar
ORIGINAL: 05ZX6R
so is that 8.8 milimeters and could u explain your self more clearer this is my 1st time installing clutches on this bike and want to make sure im doing it right bro
Old 11-03-2007 | 12:49 AM
05ZX6R's Avatar
The part you would be interested in is the 78 in/lb which is 6.5 lb/ft if your torque wrench reads lb/ft as opposed to in/lb. The 8.8 is newton-meters which is another form of power like inch/pounds (in/lb) and pound/feet (lb/ft).
By "slipper clutch", I am referring to the type of clutch that is in the 2005 and newer ZX-6R's. It allows the clutch plates to "slip" when you downshift quickly and the revs go higher. This will stop the rear tire from getting a little squirrley when downshifting fast into a corner. Your clutch is a different type so it might be a different spec on the torque setting.
Hope this helps...
Old 11-03-2007 | 03:11 AM
768 Ryda's Avatar
ORIGINAL: 05ZX6R
Hope this helps...
thx bro for the info
Old 11-06-2007 | 11:34 PM
projectroc's Avatar
Did you get that clutch changed yet? Looking for some feedback on the EBC? I can't decide...barnett or EBC !?!
Old 11-07-2007 | 12:21 AM
768 Ryda's Avatar
yes got the clutch in sunday and man what a world of difference, the steel plates was black and every last 1 of them was like that, the fibers looked ok but was worn, but i went back new with versah fibers, kg steels with oem specs & ebc HD clutch springs and adjusted the clutches to my like and this baby will power wheelie now in 1st with ease, time before that it wouldn't and i had -1+2 gearing then and now
Old 11-08-2007 | 02:54 AM
projectroc's Avatar
Do you have a part number on the vesrah fibers? Did you buy them from dennis kirk? VC-487 sound right? What are KG steels with OEM specs? Sorry about all the questions but I want to have the same clutch set-up. I've decided against a barnett
Old 11-08-2007 | 04:01 PM
768 Ryda's Avatar
ORIGINAL: projectroc
i got the versah plates off ebay, if u order them make sure they come with 9 fibers and not 8, they make 2 kits for the 03-04 zx 6r's, also i got the kg steels thru parts unlimited and ebc springs as well, yeah barnett are junk to me, they don't last long and plus the versah are what they are puttin the factory bikes now from stock
Old 11-08-2007 | 04:02 PM
768 Ryda's Avatar
and i got my springs torque down to 7 lb bc i dragrace and i needed that extra clutch for better 60ft
Ginsu4u
03-09-2018 02:39 PM
ReaperFox
07-23-2006 09:17 AM
Neuby Wan Kaneuby
05-27-2006 08:39 AM
rkutzner
04-23-2006 03:34 PM
thecount
03-13-2006 08:14 AM
