tire presure
Old 08-01-2006 | 01:25 AM
cantcme's Avatar
Default tire presure
What is the correct tire pusure for normal riding and wheeling? I get answer all over the place.
Old 08-01-2006 | 01:26 AM
evil636's Avatar
Knee Dragging Pimp
Default RE: tire presure
i usually go a pound or 2 less then whats on the side of the tire for street use.
Old 08-01-2006 | 01:38 AM
cantcme's Avatar
It says 45. I thought that was high. what you think?
Old 08-01-2006 | 01:55 AM
evil636's Avatar
Knee Dragging Pimp
put 45 in it as the tire states, ride it, see if its jars the crap out of you then drop it in 1 pound incriments. you might end up around 42 43 pounds. i wouldnt go less then 40 pounds depending on the tire.
Old 08-01-2006 | 02:52 AM
speedracer138's Avatar
For trackdays, they recommend 31 front & 29 rear. I run 34/36 on mine.
Old 08-01-2006 | 02:54 AM
evil636's Avatar
Knee Dragging Pimp
my truck says 60 if your willing to wear a neck brace. i run it at 35
Old 08-01-2006 | 03:38 AM
Notstock's Avatar
What kind of tires?
Old 08-01-2006 | 03:45 AM
Mine are the stock BT014's.
Old 08-01-2006 | 03:52 AM
Notstock's Avatar
ORIGINAL: speedracer138
Yours sounds right, 45 psi sure sounds high. I have PP and on the sreet run 31/30. with pilot race on the track it is 32/24.
Old 08-01-2006 | 04:25 AM
evil636's Avatar
Knee Dragging Pimp
ORIGINAL: Notstock
What kind of tires?
pro comp x terrains 37's i ordered a set of pilots, for 235.00 to my door. im banking off your werd ns.
Quick Reply: tire presure
