Starting issues. HELP PLEASE
I recently purchased a 99 zx6r with a little under 20k on it...bike ran fine. Changed spark plugs, oil, new gas, started right up rode for a couple hours and garaged it...the next day and it's been about 4 or 5 days goin, the damn thing won't start. Battery is good I've got power but it won't turn over. If it was litterally just running what could I be doin wrong? Any help would be greatly appreciated. This is my first bike and I'm trying to learn as I go along. Thanks!
Does the starter turn and the engine not fire, or does it not do anything at all? If the starter doesnt turn it will be an electrical issue, if it does turn but the engine doesnt start you will have to check for fuel and spark. Double check your work from the weekend and make sure you got everything back together properly and go from there. Let us know what you find, Welcome to KF!
start-up problem
One last thing. I doubt it would be your problem since you say the bike had been running, but you never know. Make sure the exhaust is free and clear of any obstruction. I've seen a 600 stopped up full of corn from a mouse that forgot where he had put it! A blocked exhaust will cause your bike not to start too.
thanks for the help!
sorry about the late update i was on spring break.thanks for all the help guys i appreciate everything. it turns out the gas switch wasnt in the on postion ::noob:: ill get the hang of it eventually. thanks again for the posts.
