Sprocket Change
RE: Sprocket Change
Have you seen the gold chains, there sweet on the bike.
RE: Sprocket Change
Too much bottem end and an uncontrolled throttle hand can spit you off the ride quicker than you can say Sh*t. Gearing for riding is important, ie majority of sweepers or tight turns for your powerband and traction limits.
RE: Sprocket Change
ORIGINAL: Stang636
That is good to hear! You think i'll still be able hit 160mph?
I will say again though -1+2, some riding skill and you will be untouchable off the corner. There are a few other factors there butit will give you unreal power.
imo gear changes are the best bang for your buck modifacation you will eever make toyour bike.
RE: Sprocket Change
Cool guys thanks for all your help. Going to order the the new sprokects. -1 in the front and +2 in the rear. Going to order them from sprokectcenter.com cant wait to feel the difference!
RE: Sprocket Change
you will still hit 160 in top gear with -1/+2 gearing. i have a speedo healer on my bike and got 162 @ rev limit. don't forget, our speedos are off when they come from the factory so don't believe that your going anything over 164!
RE: Sprocket Change
Good point ^ ^ ^
http://www.speedohealer.com/eng/intro.htm
Very easy to install and program. There is acalculator where you can input your bikes original gearing, then your new gearing and it gives you the proper set up.
