Smog removal revisited
Hey guys does anyone know anything about the way the race kit manual removes smog from 05 636? Do the crank fumes reroute to the vavle ports, I was told this, its new to me.But I was told to run a hosefrom crank to a splitter into the ports anyone knoe?
The race kit removes the hoses and valves from the top and plugs all the lines. (You can just cut a length ofremoved hose and run it between the two valve plates.)Just leave the one that goes from the top of the crankcase to the air box.
![EEK!](https://www.kawasakiforums.com/forum/images/smilies/eek.gif)
Leave the reed valves in or get an 1/8" flat aluminum stock and make some block-off plates. You can alsoJB weld the reeds. I just tied the two together with a piece of the hose I took off. Remember to plug the vacuum lines on the TB. Man,sound like you have a nice bike with a lot of goodies on it.Get an alarm and post up some pics.
