slip on pipe on a 95 zx6r
Old 08-20-2007 | 09:21 AM
zx6r_gav's Avatar
Default slip on pipe on a 95 zx6r
is there much of a gain in power to make it worth upgrading the standard can?
Old 08-21-2007 | 01:20 AM
Default RE: slip on pipe on a 95 zx6r
Welcome to the forums. Most people will do a bolt on or slip on primarily for cosmetic and noise purposes.
Old 08-21-2007 | 01:46 AM
Kohburn's Avatar
i've got a full vance and hines setup on my 95 and love it.
Old 08-21-2007 | 05:53 AM
speedracer138's Avatar
With a bolt-on or Slip-On, you can gain 2-3 HP on the top end mainly because the stock muffler is so restrictive. Some better, more freer flowing designs with mid-pipes can give you up to 5 HP on top end. Full systems can be more than that.
Old 08-21-2007 | 12:16 PM
zx6r_gav's Avatar
"Quote from speedracer138" With a bolt-on or Slip-On, you can gain 2-3 HP on the top end mainly because the stock muffler is so restrictive. Some better, more freer flowing designs with mid-pipes can give you up to 5 HP on top end. Full systems can be more than that. " end quote"
how much do you then lose in the bottom end?
Old 08-22-2007 | 02:29 AM
ORIGINAL: zx6r_gav
So at what rpm's do you normally run at? Normally, opening up the exhaust will open up the top end with a sacrifice in the lower tq end. Moving things up the scale lets say. You can always play with the cam timing to alter that too. Most people don't play that game though. Fi tuning or carb tuning will get ya close enough.
HawaiiRider
06-19-2008 02:51 AM
DJFields
06-03-2008 04:48 PM
zzrotceh
ZZR 600
12-31-2007 10:40 PM
dbdanny
12-20-2006 06:56 PM
ninjasteve
04-12-2006 10:50 PM
Quick Reply: slip on pipe on a 95 zx6r
