rev limiter q
RE: rev limiter q
I wouldn't do it all the time especially during burn-outs. Less resistance on the engine to over-rev. That is what it's designed for; to shut of ignition so the motor doesn't over-rev to destruction. You never want to rev your bike to redline in neutral because the motor will spin-up too fast; no resistance. You could throw a rod through the case and/ or bend valves if you did that. Past redline you lose power anyway because that's when the valves start to float as you can see on the Dyno run graphs.
Kacey Castle
KX250 & KX250F
01-28-2020 09:46 AM
markmeinteil
Ninja 250R
08-09-2006 01:56 AM
