REV limit changin
Old 03-17-2008 | 02:46 AM
shortie636's Avatar
Default REV limit changin
hello guys and gals out there rolling on two wheels that has a long compnay on the side of there tanks, i own a 636 '04 model and when i took it the track it only revs 13.5, juss wondering if u could change it since i need to go a lil father since i wants to bog down before the end of the 1/4,, i did the "hold the button" and it says 15.5, but it be still at 13.5... can anyone help me out,
Old 03-18-2008 | 09:13 AM
whitehendrix's Avatar
Default RE: REV limit changin
i believe that button trick is just for the shift light, and won't change the actual limiter.. the limit number is a ROM function inside the ecu.. it CAN be hacked, actually, as theres a guy on a 12-R forum thats "notching" and reprogramming STOCK ECU's with a laptop(!!) but thats a lil overboard.. i'm not an electronics engineer like he is.. just electrical..lol
if you're adiment on learning this, i'll post a link about it, (itsincredibly interesting to read)but as far as an easy way to change the rev limiter.. no way "hose-a"..lol
Old 03-19-2008 | 06:05 PM
speedracer138's Avatar
ORIGINAL: whitehendrix
Heck Yeah, I'm Adam-Ant about learning to reprogram the stock ECU!
You are correct that the rev limit cannot be changed on a stock ECU. It is possible on a race ECU (Up to 16K but highlyNOT recommended)or if you have a PCIII & Ignition Module, you can raise it by 500RPM only.
Chadzx6r
02-26-2010 03:20 PM
vfrpilot
05-30-2007 04:20 PM
Marty
10-26-2006 10:18 PM
myfault
08-28-2005 04:14 AM
Suthrn98
08-19-2005 09:30 PM
Quick Reply: REV limit changin
