Removing side turn signals.. how?
Just picked up some new front turn signal lights for my 06 zx-6r. how do you remove the stock lights? anyone have a right up? like does the whole inner faring have to come out? help would be appriciated.
RE: Removing side turn signals.. how?
beat it with a bfh..
on the fronts :::
remove the plastic on top of the bike, so you can get to the plugs.
now take a allen wrench and go inbetween the front tire and inner fairing, remove the 2 allen head screws.
take a stubby phillips head screw driver and remove the 2 screws holding the triangle piece of the fairing that holds the signal on the bike. you can jimmy it out or just take the 1 screw out of the middle of the stock signal and snap it off to get it to break from its seal.
install the new lights in the reverse order.
plug them in and test them before you put it all back togather because if you need to replace a buld, its easier to remove the signal then trying to unscrew the light cap while its in the bike.
your done
go ride.
on the fronts :::
your done
go ride.
ORIGINAL: MAD KAW
thats the best way to go.... just follow evil instructions and you'll be fine.... good job evil.... for once.....[8D]
i usually come up with a good one in every 300 posts
ORIGINAL: MAD KAW
the ones beside the tank.... those black ones on top of the fairings...
ah yes yes, nice. thanks for the write up just finished up. Super tight fit. i couldnt use one of the screw on either side, because the mounting holes didnt line up. but still very solid.
thanks again guys
thanks again guys
