reccomended tire pressure?
i recently picked up a used 04 636 w/metzler tires. the rear tire read at 41psi and the front read at 25psi or so. i looked at the service manual and it reccomended 42psi in the rear and 36psi in the front. i went ahead and did that but i don't know if it's just me but it feels way too over inflated. i filled them up while they were cold. what would you guys suggest?
RE: reccomended tire pressure?
ORIGINAL: speedracer138
I run 34 front 36 rear. It also depends on where and how you ride. I run the pressure Notstock suggested for trackdays.
oh and as far as what kinda riding i do, i use it to get to school and then at night i go out riding with friends like a maniac in the turns and slow down in straightaways lol. hopefully this combo works better b/c i'm not feeling it at all right now with what it's set at.
ORIGINAL: Ybslow
I recommend ditching the metzlers and get some good tires.
You have to try different presures. I can always spot the foo ridding down the road with overinflated tires, they have a nice big flat wear spot in the middle.
Just start at around 36 and drop a lb on each until you find a presure that works good for you. I ran that 31/30 or 32/30 for years on the street. Dunlopes and Pilot Powers.
ORIGINAL: Notstock
31frnt 30rear. trythose pressures,you will feel better.
