Rattling noise not sure the cause
I have a 2002 ninja zx6r, and i when i have the bike idling there is no rattling noise but when i hit about 3 thousand rpms the noise starts and kind of goes away as it revs higher. It seems to be louder when i am riding compared to when idle. Is it possible that its just the springs on my exhaust system or something more serious. Also what else on the bike could be making a rattling noise similar to this if it is not the exhaust system. Any help is greatly appreciated. thanks guys
Could a screw or anything small have fallen in or around the case. There is a lot of crevices that could hold a bolt. Thats what happened to me and I get the same rattling noise. Check around the bike and see if there is any empty screw holes.
thats what i cant figure out is exactly where it sounds like the slip on and yea im off the bike revving it when im tryin to find out where it is but u can here while ur on it, where all up front should i look for missing or loose bolts, is there any way to silence the springs on the exhaust if thats what it is which im not sure if thats it though
alright yeah it must not be the springs then these dont have a cover so idk what to do really if i cant find any bolts loose probably just end up takin it to a shop see if they can figure it out thank a lot for the help im a noob at all this if u couldnt tell haha
The same "resonance/rattle" occurs on the zx10r's as well in that rpm range. Most people have found the ignition causing the noise where the rivets hold the ignition in place. Not sure if that is the case here though. But it is not detrimental to the ride.
edit: Push down on the ignition key lightly during that rpm range and see if the noise goes away.
