Random Power Loss
RE: Random Power Loss
wait wait wait, dcorlando, do you know for sure now that its the throttle bodies that are bad on your bike??? cause it seems like youre thinking thats whats wrong with your bike???
ORIGINAL: uneducatedstudent
well i dont think it matters if you have the first 636 or the last 636 made, the throttle bodies are all the same on them, and the fix for the part was only recently started to be made from what i understand when i talked to kawasaki on the phone...
Well, after a cold start, it idles at around 1500 until warm, then bounces between 900 and 1000. Sometimes when I start it, it jumps to like 3000 for a sec, then back down. Also, I've been noticing it stalling a lot more often recently. About 50% of the time, if I'm cruising at say 70mph and hold in the clutch, it will stall. Sometimes it does it as low as 40mph. And occasionally, it will stall right after I start it cold. There's also no powerband when it's cold, but I think that's normal with almost all small cold engines.
o yea, i dont think that sounds normal wait for more responses, the idle and everything sounds fine, but that whole stalling out while youre riding sounds odd...only cause that has NEVER happened to my bike
