questions about changing oil
Old 07-02-2007, 06:05 AM
Default RE: questions about changing oil
ouch, normally a chain failure or crash is the prob not the engine blowing up!
Old 07-02-2007, 07:06 AM
speedracer138's Avatar
Yes, it was definitely an engine internal failure. Pistons I believe.
Old 07-02-2007, 09:17 AM
kazerotor's Avatar
I had put some castrol fully synthetic oil 10x40 and it seems to shift harder now. anyone have suggestions for something better? i want to put mobil 1 in it but i can't find a dealer that sells it specifically for motorcycles. i was also thinking of trying out 20x40 but i don't know if that's too thick
Old 07-02-2007, 01:28 PM
vermont6r's Avatar
I use Mobile 1 10w40. The bike shifts well and hasn't consumed any oil yet. I bought it at walmart so i would check there before searching further for a dealer that sells it. I'm sure dlr markup on Mobile 1 is significantly higher than at wally-world.
There's a sticker near the oil window that specifies how much oil add depending on the scenario (i.e. fully drained, filter still on, etc) so that takes the guess work out of it.
Old 07-03-2007, 04:59 AM
Daves_636's Avatar
dont forget the proper torque on the filter. i think it is 22 or 23. safety wire is a good idea too. k&n filter has the hole for it and the bolt head to torque.
i think the oil drain is 22 and filter 23. just did mine last weekend.
only removed black lower fairing left side. easy access to the filter. dont forget to lube the rubber on the filter.
Old 07-15-2007, 12:23 AM
alexanderm's Avatar
if this sounds retarded sorry but where do you add the new oil?
Old 07-15-2007, 01:18 AM
ORIGINAL: alexanderm
hahaha, that is deff a newbie question. I also take it you do not have a manual to play with your ride? The oil filler is on the right case. Has a ****/handle on it. The sight glass will be underneath it. Only fill 1/2 or where the lines are on the sight glass. Get a manual if you plan on playing with your toys.
edit: Ouch, that sounded harsh. Get your basics down and all is well.
MJohnson
Ninja ZX-9R
03-20-2011 03:17 AM
Kristiinaaa
05-10-2009 09:31 PM
joepa
04-23-2007 10:33 AM
kawi636
04-04-2006 09:26 PM
06black636
02-05-2006 02:01 AM
Quick Reply: questions about changing oil
