question about seafom
Old 07-12-2008 | 04:44 AM
768 Ryda's Avatar
Default question about seafom
hey guys can u add seafom to a bikes oil with out causing clutch slippage or any other internal engine damage, i read the bottle and it says u can use it in a motorcycle, but is it safe tho, also whats the best way to use it in the bikes oil or gas tank
Old 07-14-2008 | 05:11 PM
Kohburn's Avatar
Default RE: question about seafom
i don't believe in adding seafoam to oil unless you are doing it just before draining the old oil
Kohburn's Avatar
seafoam has a lot of solvents in it that thin down oil, imo not good for bearing life. but used before an oil change it can flush out grime buildup.
Old 07-15-2008 | 12:02 AM
768 Ryda's Avatar
how long do u guys think it will be safe to run in the oil before oil change
Old 07-15-2008 | 02:05 AM
Why would you do this ryda? You forget to change your oil 20,000 miles ago?
Old 07-15-2008 | 11:36 AM
768 Ryda's Avatar
ORIGINAL: Dragone#19
no i change my oil reguarly but talked to a guy and he performs maintence reguarly also and he said he noticed a difference with useing this stuff
1stCruiser
04-23-2011 03:27 AM
fastex500
03-28-2008 01:41 AM
BlueDream
11-21-2007 05:35 PM
Quick Reply: question about seafom
