psi on back shock
Do not adjust the air in the rear shock. It is set from the factory and does not need to be adjusted or messed with. The only adjustment you need to make are spring preload, compression and rebound dampening on the rear shock.
the air was let out before i bought it to make it sit lower.
and actually i found out that i believe it uses nitrogen. bike feels a little akward in the corners and im wondering if this is the reason why.
