powercommander rant
powercommander rant
So I installed my PCIII, and now my bike runs like crap. -_- It seems to be sluggish all throughout the rpm range and it also sounds like crap. Kinda felt like I was riding a crusier. heh
So I guess I gotta DL a new map or something. Jamie from fuelmoto programmed it, but I guess he used the wrong map or got it mixed up with someone else's.
I wish i had a laptop to use. -_- I dont really feel like uninstalled in, and then hooking it back up, again.
RE: powercommander rant
Yes, check all your connections to make sure you didn't laeve something unplugged. The maps are slightly different in fuel timing & mixture, but should not make your bike run that bad. Double check your connectors. Again. And your harness grounds also.
Aight, i am sure the ground is good, cuz its right on the battery, and not loose. I was sure the connectors were all tight, but maybe I missed one that was alil loose. *shrugs* Yea, I didnt ride it for long till i brought it back home.
EDIT
Ok, so I took my bike apart again, and found a connector that came un-done. I was sure I checked all of them. I started the bike up, and it sounded good/normal. So I took it out for a spin, and it worked great.
Werd.
EDIT
Werd.
I feel a slight increase in power, but not too much. I guess gettin a leo vince header.
And no, I haven't done the jumper mod yet. I dont know much about that mod, whats it do?
ORIGINAL: speedracer138
Billy, Try different maps until you like one that feels good even if it's for a different pipe.
I have noticed, that on start-up, when my bike is cold, that it seems to sputter a lil bit at like 1000 rpm or so. But after it gets warmed up, it does not do that anymore. Is this due to the new pipe and PCIII?
Also I have noticed that I have to hold the start button in longer than before I put the PCIII on. Now, I gotta hold it in for like 3-4 seconds or so. Is this also a side affect of the PCIII, or is something wrong?
