Power Commander Necessary?
Old 09-09-2006 | 07:51 AM
speedracer138's Avatar
Default RE: Power Commander Necessary?
MO POWA!! Especially top-end.
Old 09-09-2006 | 07:57 AM
Knivez's Avatar
im sold lol
Old 09-09-2006 | 09:51 AM
uneducatedstudent's Avatar
first time i get the cash, thats the first thing im getting besides the stuff i got already thats gonna make my bike look sexay
Old 09-11-2006 | 06:47 AM
5thgen's Avatar
ORIGINAL: speedracer138
The whole reason it flows freer is to allow more air with less restriction, and with more air comes in more dirt/ dust. All the really fine stuff the stock air filter stops will go through the K&N or BMC. You can see light through those. And airflow follows the path of least resistance.
Very true. K&N filters allow more air to go through, but it also allows fine particles to go through too.
Old 09-11-2006 | 08:51 AM
tigersurvival's Avatar
MO POWA!!
Lmfao... you should be a salesman guy.
Old 09-12-2006 | 12:00 AM
dcorlando's Avatar
BMC or K&N will improve the performance but not the life of the engine. The whole reason it flows freer is to allow more air with less restriction, and with more air comes in more dirt/ dust. All the really fine stuff the stock air filter stops will go through the K&N or BMC. You can see light through those. And airflow follows the path of least resistance. As long as you dont mind rebuilding your engine sooner and changing the oil & filter more often than recommended.
In terms of rebuilding the engine... this means re-honing the cyliders and puting new piston rings in, and that's it right (minus all the new gaskets and oil)? Being as these may very well be the last 636s for a long time and that I commute on mine, I want it to last as long as possible. I've done tear-downs on dragster engines before, so I know I can handle the mechanical part, which is usually what costs so damn much to have done.
What I am getting at is if the only thing between my bike and eternity is rebuilding the engine every 40k miles, then can I spend the 100 bucks in parts and do it myself, or is there more to rebuilding a motorcycle engine in comparison to a car?
Old 09-12-2006 | 06:11 AM
It's about the same. Just have to make sure ALL the clearances & tolerances are within limits. Honing the cylinders (or boring them 1mm over if necessary with new pistons: Go Forged). You can get a bigbore kit & get more CC's also. Rings, Main & Rod bearings, valve job, seals & gaskets & new camchain. If you have done dragster engines, you shouldn't have any problems. The parts are just smaller and more of them.
KLXelent
04-26-2012 05:02 PM
Marty
03-07-2008 06:23 AM
marcus13
03-04-2008 02:43 PM
zzrotceh
ZZR 600
12-31-2007 09:40 PM
fastex500
06-16-2007 01:23 AM
Quick Reply: Power Commander Necessary?
