POWER COMMANDER
POWER COMMANDER
I HAVE 03 636 I JUST INSTALLED FULL YOSH. AND PCU III. THE PCU IS PROGRAMED FOR WHAT I HAVE. I TOOK THE BIKE OUT AND PROBLEMS LEAVING AN 05 GXR . MY QUESTION DOSE ANY ONE HAVE A BETTER MAP OR SET UP THAN WHAT FROM DYNO JET? ANY CUSTOM SET UP OR ADVICE IS APPRECIATED.
RE: POWER COMMANDER
Well my friend you have a few options. 1 you could go to the DynaJet website and look for other Maps to download. You really have to play a lil with the power commander to see where you are running at what % throttle to RPM range.. 2 The best bet to do is take it to a shop that has a Dyno and run it, and they can tell you the best Map to put in. Good Luck and keep us posted with the outcome.
RE: POWER COMMANDER
Yes, you can try the different MAP's to see which one works best or if you can afford it, Have it Dyno Tuned at a Dynojet approved shop for the best results & most HP.
RE: POWER COMMANDER
European bikes had a different ECU program (easily fixed for US models), Ignition Immobilizer (security system)and the Euro running lights in the headlight. Oh, they talk funny too. LOL!
