over heating???!!
Old 06-04-2007, 12:56 AM
Bluebeast's Avatar
Default RE: over heating???!!
Wow that is hot. I would try what speed said. hopefully it's not the fan motor and just some thing simple. like a fuse or connection.
Old 06-04-2007, 03:11 AM
cway246's Avatar
Well I did test the fan switch by giving it voltage and nothing happened so im pretty sure its the fan motor. However I think that should be covered in warranty. Ive had the bike for a month and so far has been nothin but trouble! Almost considering selling it, just afraid I wont make my money back.
Old 06-04-2007, 08:39 AM
speedracer138's Avatar
Try hooking up the battery wires directly to the fan motor instaed of the switch.
Old 06-04-2007, 02:53 PM
Bluebeast's Avatar
if the fan works after hooking up up strat to the batter then it's the switch and that will need to be changed out. It shouldn't be that much to fix ifit is. Or just take it to the dealer and let them fix it for you.
Old 06-06-2007, 05:14 PM
cway246's Avatar
It ended up being a fuse, i figured i would check all the fuses in the box and one was no good. Thanks for the help.
Old 06-06-2007, 05:52 PM
aszrael1266's Avatar
The Dude
glad to hear the problem is fixed.
Old 06-06-2007, 07:35 PM
mikeyntnc's Avatar
Glad you found the problem .Always check the fuses first when you have a problem of this nature , it might save some headache and hassle .
Old 06-06-2007, 08:36 PM
Plus it's the easiest. I thought you checked that first already. Always start with the simplest first.
Old 06-07-2007, 05:40 AM
Daves_636's Avatar
if the fuse pops again then you might have a problem. make sure you carry spares with you in the spare slot.
jfirme
09-19-2017 07:04 AM
TyCobb2000
07-09-2011 06:28 AM
justin
11-13-2006 02:56 AM
Joe00zx
10-10-2006 06:22 AM
evil636
03-21-2006 09:12 AM
Quick Reply: over heating???!!
