Oil change
Old 06-19-2006 | 09:33 PM
zzone's Avatar
Default RE: Oil change
thanks a lot , i hope this will help me...when i'll change it.I think that would happen over a few weeks cose right now i don't seem to find time.
Thanks a lot
Old 06-19-2006 | 10:28 PM
speedracer138's Avatar
Valvoline makes a good 4 stroke motorcycle oil. You may have to order it at Autozone but some have it in stock. It's formulated for motorcycle wet clutches. I run Valvoline 5W40 Synthetic in mine. Royal Purple is good stuff also. I was impressed with their bearing load test at a Corvette show I once went to. Showed the least amount of wear compared to other oils. It's hard to find stores that carry them. I used to use that in my Autos until I switched to Valvoline Synthetic. They're all good oils; just depends how often you change them and how hard you are on your machine. Amzoil is another good brand. Mobil1, Amzoil, Royal Purple are Full Synthetic as is the Valvoline Synthetic. I'd go 5W40 unless you're in a very HOT climate; 110 degrees plus. Read your ownwers manual for recommended weight oil.
Old 06-24-2006 | 08:49 PM
Odimus's Avatar
I'm running Repsol full synthetic now and I have no complaints...
yjsjin
07-12-2009 12:28 AM
cwgoff
01-30-2007 09:23 PM
slablocal
07-08-2006 08:21 AM
Red636guy
04-24-2006 09:50 AM
Quick Reply: Oil change
