Oil
#32
RE: Oil
ORIGINAL: movin_up
Should I run semi-syn since I dont have that many miles (2300)....whats a good mileage 2 start semi or full???
#33
RE: Oil
I went to full synthetic at a little over 3000 miles. You don't have to go semi-synthetic. The oil viscocity is a set standard. Regular mineral based oils & synthetics of the same (SAE 10W40) weight are the same except the synthetic doesn't break down as fast, has better lubrication qualities and withstands higher temperatures. Actually, A looser engine will put out more horsepower due to less internal friction and the synthetic oils will only help.
#34
RE: Oil
ORIGINAL: speedracer138
#35
RE: Oil
I'm not saying THAT LOOSE. A little looser than when NEW with a few thousand miles. All the racebikes use a lot looser tolerances than normal for less drag & more horsepower. As long as the rings seal good, there won't be any blowby. My bike seems more powerful now that when I first got it and the dyno results have proven that with other bikes as well. Same exact bike, same mods (no changes) except for more mileage.
#36
RE: Oil
Heavens, thanks for all the responses folks, really helping me out. After reading everyone's posts I've decided to go with a "Regular" Full Synthetic along the lines of Mobile1 10W-40. It's going to start getting colder soon and I think the 10W40 won't break down as easy. I don't mind changing oil for the things I ride/drive, and I'm going to have to drain the bike for when I put it in storage when I deploy in May of 07' -- so it should last. I wrecked my bike with 160 miles on the odometer so I think it's safe to introduce the synthetic. In case you guys forgot I bashed my Alternator Cover (<--avatar picture) open and all the oil came pouring out... s'why I need to add some oil to my bike.
#37
RE: Oil
Get that cover replaced or fixed if you haven't already. It's dangerous and bad for the bike also. You can get sand & crap in there and it'll start to wear things out.
#38
RE: Oil
Icantrideabike
09-22-2006 02:58 AM
Jutboy
04-21-2006 06:05 PM
