ninja 600r starting problems
Old 07-19-2010 | 02:30 AM
carpenoctum's Avatar
Default ninja 600r starting problems
how do i remove the starter? wheni turn the key to on, and try the electric start i can hear a faint buzzing noise coming from the junction box under the seat, the box is good and the fuses (tried it on another 600r) i don't hear the starter engaging nor is it getting power, the battery is good a full 12v runnin thru the batt, so it would have to be either the starter or a cable runnin to it right?
any ideas on how to diagnose as well as how to fix? im good with cars, new to the bike world so things are a little confusing... thanks
Old 07-19-2010 | 05:12 AM
Prom's Avatar
Starters rarely go bad, but I have seen it happen. more commonly its going to be a bad connection or a bad battery. Check all your connections and have your battery load tested. If the battery is bad it can hold 12v but not enough amps to turn the motor.
Good luck, and Welcome to KF!
Old 07-23-2010 | 02:35 AM
check your relay. Weak connections and relays are prime suspects on most of the 90's and 2k rides. Not sure on what you have yet, but hit up your fiche. About $70
snyd-clk
07-08-2011 04:07 PM
lenotonight
09-15-2007 02:15 AM
MidnightNinja
02-18-2007 06:07 AM
lotsaboost
08-05-2006 03:44 AM
Kais3rboy
01-07-2006 08:09 AM
Quick Reply: ninja 600r starting problems
