New exhaust
RE: New exhaust
[quote] evil636
JUST OUT OF CURIOSITY AIRMANALLEN, HOW DOES AND WHAT DOES THAT PLATE MOUNT BOLT TO ? [quote]
There are two bolts already sticking out of the bottom of the undertail. The kit includes two longer bolts that the bracket attatches to. You have to drill three small holes in the plastic to route the turn signals and plate light. You also have to cut the factory plugs off each light and splice them into the new lights. It's very easy and the instructions are farily detailed.
RE: New exhaust
ORIGINAL: stylin97
got any pics showing exactly what you used or how you did it?
and what are you doing for turn signals/license plate light?
ORIGINAL: evil636
heres a pic.
heres a pic.
the lic plate lights consist of two "light in bolts" mainly used on hot rods. they bolt into the two top plate holes. there really is no complicated way to describe a plate mount. the stock bolts coming out of the bottom of the bike were replaced with longer ones, i took my piece of metal, cut it, roll bent it and shaped it up a little, cut some holes in the back with a hole saw and a drill press, drilled my mounting holes and bolted it up. ill get some pics of the lights mounted up as soon as they come in.
