New with Dyno Run
New with Dyno Run
hey guys how you doing?? well ive had my zx6r for 2 yrs now and love the bike, ive been reading the forum here for awhile now and finally registered... Just have a question I see many guys get nice hp numbers on their bike in excess of 113hp to the wheels... i dynoed my bike today it has a scorpion slip on, k/n filter and jumper mod and only got 111.86 hp and 45.62tq to the wheels... it was dynoed with 25% load.. I would like to hear some opinions and il be posting the dyno sheet soon.. I was kinda dissapointed with these numbers from seeing some of you guys making way more power just would like to know if you guys dynoed with just inertia or with load on bike... i also noticied my bike is running very lean on the dyno readings were between 13.4-13.8 throughout the map... im considering a power commander or the kawi ecu but I havent met any1 thats actually installed one and worked with it... any suggestions???
RE: New with Dyno Run
Welcome to KF. I'm no expert with numbers with the dyno but I'm sure someone here is. A full exhaust and pc3 would definatley help, Should be able to push 120.? hp. at the rear wheel. Stay tuned for more info from more knowlegable people!
Again I'm not an expert either and never had my bike dyno'd. But I after I installed my PC3 it made a huge difference. Throttle is more responsive, and more torque thruogh-out the power band. Plus it's fun trying out new maps. I highly recommend getting one and possibily you can get the numbers you're looking for.
a pc111 is what u need if your runnin lean, i have a 04 636 and it made 115hp at the rear wheel, mods are pc111 with a custom map, k&n filter with air box mod, d&d exhaust on premium gas, on U4 race gas it made 120.8, took the sec flies out and lost alittle down low but gained it back up top so i put them back in, not to bad for a bone stock 636 with just bolt on parts, get that pc111 and get it tuned and i think u will find your no#'s u are lookin for
pciii will definately pick up some of your power. what was his motive for 25% load? it also depends VERY much where your located at. ie: altitude, humidity, TEMPERATURE!! depends where you are depends on how your bike performs. But without the pciii, you will never know the full potential of your bike. believe it or not, the tire you run has alot to do with it too. any questions let me know, i work at a performance shop. Certified dyno tech
ORIGINAL: Ratkiller
ORIGINAL: kory636
i do not recommend the dynojet maps. they will usually hurt your bike more than help it. Just because they wont on one bike does not mean it will with on another identical bike. EVERY bike differs. Only way to maximize is for a custom dyno. Otherwise, the pciii was a waste of your money. Those maps only optamize 100% throttle, so that leaves 0-99% to screw up. TRUST ME, it will be the best thing you could ever do for your bike. Dont know how much it runs where you are, but here in FL they run about $300 for a full dyno.
ORIGINAL: Ratkiller
Thanxs for the info guys... there was a 25% placed on the dyno so it tells me what im making on the street, since on the dyno you cant simulate wind resistance you place a load on the dyno so you can get what you are really making instead of doing with inertia so thats why im guessing my numbers are lower... i also did some research and found out bikes and cars tend to run leaner on the dyno than on the actual street... im really thinking about the power commander but ive been looking at the kawasaki race ecu and it interest alot more since I can play with timing from 0rpm all the way to 16k which I dont plan to go all the way up there... the dyno I dynoed my bike was a dynojet 250i.. i mean im down here in miami and the guy at the shop showed me other dynoes from other 636 with same bolts on i have with a usb and they are making what im making... so i really dont know.. im having one of my friends dyno his stock zx6r to compare with mine
