motormount nut
Old 06-12-2007 | 08:49 AM
free_dumb_snow@yahoo's Avatar
Default motormount nut
I bought some frame sliders recently and just put them on, when tightening the right side the nut stripped. I tried to speak witht the kid at the local kawasaki dealership, but I am pretty sure he ordered the wrong nut. I am wondering if anyone has done the same thing and knows where else a similar nut could be found.
Old 06-15-2007 | 05:32 AM
Gymratt500's Avatar
Default RE: motormount nut
When you say "nut", do you actually mean the bolt that holds the frame slider on. Not trying to be sarcastic, but I haven't personally seen a frame slider that uses any nuts for attachment. Usually there is just a long allen head bolt that goes thru the frame slider and directly into a threaded hole on the bike frame.
Old 06-15-2007 | 05:35 AM
Gymratt500's Avatar
If it really is a nut you are referring to, just bring the bolt to the hardware store and find one that will thread on correctly. It's usually best to use stainless steel, or grade 8 hardware. If you stripped the threaded hole on the frame, purchase what is called a "heli-coil". They are used to repair stripped threads and are very easy to use.
Old 06-15-2007 | 05:47 AM
buy some locktite if you need to use the helicoils.
Old 06-15-2007 | 09:42 PM
shinobi636's Avatar
There is a nut on the back side, inside behind the mount tab. I would take one of the bolts to the local hardware store, and just buy them. Get grade 5, or 8. They should only be fifty cents to a dollar each.
tommytuttle
08-11-2011 02:23 PM
06-12-2007 08:54 PM
2001ninjaZX6R
07-20-2006 07:02 AM
konacoiler
07-07-2006 04:34 PM
jds636
05-01-2006 09:05 PM
Quick Reply: motormount nut
