low coolant?
low coolant?
i was just replacing my filter with a k&n and i was checking the coolant.... it was below the low!!!!! i freaked but neways.... do u guys think i have a leak???? i have never put a drop in it or flushed it. i was wondering if i should be worried or just put more coolant in?? also if all i need to do is add some do i just put some regular coolant from the local auto parts store??? i know there is water wetter and others like that but i think that would be if i was to change it or flush it. i have 7k on it also
RE: low coolant?
Add some and go from there. If your bike isnt running hot, you dont need to worry. But it can be the little cheap things like that, that can cause big expensive problems in the long run.
