Locked Front Wheel Please Help!!
I bought an 05 636 last week that was laid down. I rode last Friday for a few miles and everything was fine. Haven't touched it in a week b/c the weather was crappy. Today I go out and the front wheel is locked. Tried to take off the calipers and they were stuck like glue to the rotors. Finally got them off and it seems that the left caliper is not releasing. I tried to push the pistons back in and as soon as I do one side the other tightens back up. What should I do next? Take the caliper apart? Thanks for the help.
RE: Locked Front Wheel Please Help!!
Yo. I have that same bike. Im sorry to hear it was laid down. With out looking at it it seams as thou your on the right track. I think you mealted the pad it self to the rotor. pistion sounds siezed. With out damaging the rest hammer it apart or pry. Try taking the rotor off. After you didconnected the lines and all other parts. See if tht helps let me know how its coming.
well silverr6 first thing to do is say hi in the newbi section but since ur desprate we will let it slide.Did u take the cover to the master cylnder off when pushing the piston back in?
ORIGINAL: hoedogg
When you laid it down, some air probably got in there fron the Master Cylinder and expanded. Try relieving the pressure by loosening the bleed screws and do a thorough bleeding of the system including the Master Cylinder. Make sure that the piston moves freely when you push it in with the bleed screw loose. (Be ready for Brake fluid to squirt out at you; Wear safety glasses or ?.)
Get a new one. They are not that expensive and it can be the difference between brakes that stop and ones that let you hit the car stopping quick in front of you. Never mess around with faulty brakes.
