LIGHTS OUT
Old 03-15-2007 | 04:35 AM
mikedrinfla's Avatar
Default RE: LIGHTS OUT
Make sure the drw on the bilb is not to extensive. If it is draw to much power you will pop fuses and burn up the wire. What is the draw on the bulbs you are using? I had soem high draw bubls on my truck and I had to replace the whole wire harness.
Old 03-15-2007 | 08:39 AM
speedracer138's Avatar
Too much resistance is why the fuse blew. Make absolutely sure that you have a good ground. Remove the paint from the frame ground point to get the best contact. Make sure the bulbs aren't over 60/55 watt rating and all crimps & connections are good and secure. Also, don't go over 15 amps on the fuse; try a 12.5 amp one first but double check your connections. One other thing, if you got the kit from me, check the bulbs to make sure the welds are good because I did get a bad batch of bulbs. I have been double checking them all.
Old 03-15-2007 | 08:55 AM
xmxracer's Avatar
SO FAR SO GOOD, BUT IF THE 15AMP FUSE DOESN'T WORK I'LL SURELY CHECK THE GROUND FIRST AND THEN THE OTHER CONNECTIONS. I SURE APPRECIATE ALL OF THE HELP.
Old 03-15-2007 | 08:58 AM
You should check the ground & bulbsasap anyway. Better to be sure than to burn up your harness or bike.
Old 06-01-2007 | 09:49 PM
ptownbrown's Avatar
my bike did the same thing last night. i got new fuses but i havent checked the ground or bulbs yet. if i got bad bulbs from you (speedracer) im guessing your going to be sending me new ones?
Old 06-01-2007 | 10:09 PM
mikeyntnc's Avatar
It would be a real good idea to go thru the wiring to make sure your not shorting a wire .Start with the ground .
Old 06-02-2007 | 01:30 AM
Bluebeast's Avatar
I agree with checking the ground. And sorry for the highjack but speed how much to duel the head lights from you.
Old 06-02-2007 | 12:49 PM
afboundguy's Avatar
I'm interested in getting the dual mod from you as well speed. How much?
Guydiver12
04-15-2008 01:21 PM
firsttime
Ninja 250R
10-25-2007 12:49 PM
onestarr99
12-22-2006 06:08 AM
Quick Reply: LIGHTS OUT
