LIFTER NOISE...
Old 05-13-2007, 06:52 AM
speedracer138's Avatar
Default RE: LIFTER NOISE...
It's on the cylinders on the RH upper side. You can get the Factory race kit one for around $70 or an APE for $50. You have to have the #1 Cylinder in TDC and keep the slack in the timing chain on the tensioner side when installing it.Use the servicemanual when installing it; you don't want to jump any links on the timing chain.
Old 05-13-2007, 08:10 AM
Mott Power's Avatar
speed racer is correct i would believe, the 250's have that as well, i thought it was the valves but the noise was too external, its the tensioner spring that isn't putting enough pressure on the chain, easy fis usually
i haven't checked it myself but this is what i have heard
Korr
02-17-2008 01:22 PM
afboundguy
05-11-2007 01:10 AM
RyderXS
Ninja 500R
08-29-2005 03:50 PM
Jkuchera
07-29-2005 10:14 AM
joe sprocket
07-20-2005 11:24 AM
Quick Reply: LIFTER NOISE...
