licenc plate light
Old 02-07-2006 | 06:40 AM
AKRider's Avatar
Default licenc plate light
i just purchased a 06 636, and since it is is winter up here, i have free time to do stuff to the bike. i want to take the mud guard thing off and do sone cutting on it to make it sorta go away. i know there are kits out there but that money that could go other places. i tryed to take the light off and i couldent find a place to disconect the wires i really dot want to cut them. any help will be appriciated. thanks
Old 02-07-2006 | 07:52 AM
evil636's Avatar
Knee Dragging Pimp
Default RE: licenc plate light
the plug is on the clutch side of the bike right before the zx6r logo under the rear tail section of the plastic. check my gallery for pics, might help as a refrence.
take the side covers off (by the tank
remove the 2 bolts that hold the front seat on
remove the rear seat
take off the 7 bolts holding the tail section on
on the front break side the black plastic is held on with a grommit and pin, pull it out carefully
on the clutch side after you remove the side panels theres 3 pins holding the plastic on, push the centers in and use your fingernail to pull out the pins from their base. to install them push the centers so the tips are sticking out, incert and push the center pins flush.
slide the tail section back and disconnect the tail light plug.
remove the tail section.
reverse order to install.
Old 02-07-2006 | 11:22 AM
AKRider's Avatar
just checkin that was for the break light right? i was lookin for the licence plate light?
Old 02-07-2006 | 11:41 AM
evil636's Avatar
Knee Dragging Pimp
you need to get all that off to get to the lic plate light plug. yes lic plate light.
Old 02-08-2006 | 08:34 AM
AKRider's Avatar
Thanks for the help i took it apart this evining
Old 02-08-2006 | 09:07 AM
evil636's Avatar
Knee Dragging Pimp
was it all where i said it was because i was tired when i wrote that.
olderthandirt
01-10-2009 01:14 PM
ktn
11-08-2007 03:11 PM
Shrumple
05-30-2007 02:20 AM
Rains
05-03-2007 05:37 AM
Nobrakes
02-05-2007 05:37 PM
Quick Reply: licenc plate light
